cant get the caliper bolts loose wat can I do
trying to replace caliper and rotor but cant get the bolts loosened
Это хороший вопрос?
Оценка
0
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 19
are the bolts super rusty or do you lack the right tools to get them loose?
из Jesse Hooton
they r super rusty i bought bolt extractor set from advance but havnt tryed it yet
из jd77766
Get a can of Aerokroil and a heatgun (not a hairdryer) If you use a torch you better be good with it - Much easier to damage stuff with it. Heat each bolt until you can't touch it, then spray the Aerokroil into the seam between the bolt head and caliper. Do this at least twice with a few minutes between. Aerokroil is the best penetrant I've seen. I owned an automotive underbody repair shop for 18 years.
из Kevin Sargent
