Fan stuck on full
The Mac is just idling on the desktop with TG pro open and the cpu package is 69 degrees, however the heat sink is cool to the touch
MacBook fan is stuck on full. It was suggested I replace the actual fan, I have done so and it has not fixed the problem. Here is what asd says:
Also this is what’s macsfancontrol has to say on the issue
Это хороший вопрос?
Lets take MacsFanControl out as I don't trust it! Make sure you've fully removed it.
Now take a nice tight picture of the fan connector so we can see the connection Adding images to an existing question.
I prefer using TG Pro then running the Apple diagnostics as you need to be sure you are using the correct version for the given system.
из Dan
