The Golf Mk4 was first introduced in August 1997, followed by a notchback version (VW Bora or, in North America, again VW Jetta) in August 1998 and a new Golf Variant (estate) in March 1999.
Вопросов 20 Показать все
reset radio golf 2003
Have a Volkswagen Golf 2003 model. How to reset the radio?
Have some errors I believe can be solved with a reset..
The problem is, I use the up-down buttons and switch radio station with nothing happens ..
Antenna is replaced it must be the radio
Это хороший вопрос?
Оценка 0
3 Комментариев
and always make sure that you have the right reset code.
из
This has been tried!
It does not work. Electricity was off for 30 minutes, and the radio did NOT ask for the radio code.
из
This question was migrated from http://meta.ifixit.com/Answers.
из
Добавить комментарий
Ответов (1)
Выбранное решение
Hi,
take of the ground wire from the battery for about two minutes, then put it back on. This should do a reset not only to the radio, but to the whole CAN-Bus system as well.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
+flat battery/disconnecting etc has always reset my radio!
из
Добавьте свой ответ
Kjetil Pedersen будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 11
За последние 30 дней: 20
За всё время: 10,435
