Repair guides and support for automobiles by Volkswagen.
519вопросов Показать все
while trying to start realized the cam is not moving just swings
hi guys i have a citi 1.4i mp9 car just died when driving i than checked the the plugs seems fine i checked the plug wires seems fine i than open the cam timing cover to check to check if the cam is moving while trying to start realized the cam is not moving just swings no power what else could i check
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It sounds like you have a bad timing belt or chain. Unless you are a mechanically inclined person I would take it to a shop and have it checked. If it broke while you were driving and it's an interference engine you will have to have the head pulled off and new valves replaced with any bent ones and a new belt or chain and tensioner.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jermaine Edwards будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 20
