Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
Replacement battery not recognized, not OEM specs
On battery install, warning about not recognizing battery. I turned off notification in BIOS. It registered 60%, I drained for calibration, now won't work without adapter plugged in and reads battery as 0%. Shuts down when adapter unplugged.
Это хороший вопрос?
Счет 1
2 Комментариев:
where did you get the battery from? I wonder if Dell serialized the battery, essentially tying it to that specific machine...
из
I got mine from I fix it and same problem. Warning message on startup that it is not a Dell battery and it refuses to charge it ?
из
Добавить комментарий
1 ответ
Dell has stopped supplying these batteries, and my bios tells me the battery is not recognized. I purchased from IFIXIT
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Reggie Stecher буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 376
