Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1502вопросов Показать все
What is wrong with my wifi?
I am running on IOS5 and my wifi was not working so i got a new wifi part and it is still not working. I have restored and jailbreaked many times and it can never detect a network even when my other devices can.
Это хороший вопрос?
Оценка -1
2 Комментариев
the Bluetooth works i was able to connect to my blackberry
из
i am unable to detect networks when i open wifi, i purchased a new attena and there is no difference
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Can you please look up the following:
- Is your wifi greyed out (i.e. not able to open the wifi menu at all) or is it just unable to find networks?
- Lookup under Settings / General / Info the WIFI Address (MAC ADDRESS)
If your wifi is greyed out and/or there is no WIFI Address then there is probably not a problem with your antenna but there is a problem with the WIFI chip.
If your wifi is not greyed out try standing as close as possible to the router to see if you get wifi signal then. If you get it then there could be a problem with your antenna OR the circuit on the logic board going from the WIFI chip to the antenna.
Please let me know the results so I can help you further.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
из
Ok then you probably have a problem on the logic board. If you are certain that the antenna is correct and the connector is in place you might consider reflowing the WIFI chip and the coil next to it.
In the following YouTube video it is explained how to reflow it: http://www.youtube.com/watch?v=7E34y9l49...
из
ok maybe it is the attanna, its now fluctuating in detecting the network and not detecting
из
My 3GS IOS5 has the WiFi grayed out and No WiFi. Have reset Network Setting, no wifi address. What now? This happened when did 5.1.1 update. Had to restore phone in order to complete update and now no WiFi
Оценка 0
1 Комментарий:
there were problems with the ios 5.x update and greyed wifi which were meant to have been fixed see if you have any earlier ios restores in your itunes library to go back to. You may need to do a jailbreak..https://discussions.apple.com/thread/395...
из
Добавьте свой ответ
phil будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 6,140
