Smaller version of the original iPad Pro. Released March 31, 2016. Features a 9.7" display, A9X processor, and 32/128/256 GB storage options. Available in Silver, Space Grey, Gold, and Rose Gold.
147вопросов Показать все
Ipad will not turn on after battery replacement?
As the title states, I replaced the battery in an iPad Pro 9.7”, and now the iPad won’t turn on. No LCD display.
I plugged the iPad into a laptop and it was recognized by iTunes.
The installation went fine and without problems, and I’ve done it before, so I’m confused what the problem could be here. I’ve triple-checked all the connectors and everything that could be loose to prevent the LCD from powering up, and I can’t find anything. Any advice would be appreciated
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
was the battery connected when you connected the display? sometimes people can blow the backlight circuit when they connect the screen while the battery is connected. If you shine a flashlight on the display while attempting to wake it up or turn it on that's a quick and easy way to diagnose a blown backlight. also what did iTunes say when you connected the device? Was it in recovery or DFU mode?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
It is in recovery mode
из
@janedoethethird glad you got it resolved!
из
Добавьте свой ответ
Jane Doe III будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 240
