Samsung Galaxy J2 — это смартфон на базе Android, выпущенный в ноябре 2016 года.
Samsung j2 charging problem
my Samsung j2 is not charging can I fix the port
Это хороший вопрос?
Счет 2
1 Комментарий
Display change
из
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Just verifying that you tried a different, compatible known working charger, charger cable or connected the phone to a computer and also visually inspected the charge port using a strong light and a magnifying glass to check if the port was blocked with lint etc preventing a good electrical connection, to prove that the charge port may be the problem, as you didn’t say? If the port is blocked then try using a vacuum cleaner to suck out the debris. Do not use a metal pin or probe to get it out as you may damage the pins.
If you have checked all the above and determined that it may be the charge port then here’s a video that shows how to replace the USB port The supplier linked is an example only to show the part and cost. There are other suppliers online that may suit you better. Search for Galaxy J2 USB charge port dock connector, to get results.
You will need smd soldering skills and tools to do the repair.
Был ли этот ответ полезен?
Счет 4
Добавьте свой ответ
calstyle99 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 34
За все время: 1,074
