Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите «Прикрепить комментарий к этому сообщению», чтобы переместить его.
2 Комментариев:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
из Anonymous
из ruth
