The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
81вопросов Показать все
Direction button is unresponsive?
Does the circuit board have to be replaced if the direction button is not working or can it be fixed?. It is only when it is pressed upwards all other directions seem to be working ok. The case has not been changed its the original.
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
The rubber underneath the directional button needs replaced or the motherboard needs cleaned where the rubber piece makes contact. You will need a triwing screwdriver to take it apart. Be careful with the video cables. You will need to remove the motherboard to repair this. Instructions for that are here.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
fernanda будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,058
