Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
103вопросов Показать все
My MacBook air A2179 screen went blank. How do I fix it?
I was able to go to recovery assistant using VoiceOver but the screen will only show a faint backlight
Now I’m stuck at Recovery Assistant Voice Over. Screen only has a faint backlight.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
See if resetting the SMC brings things back How to reset the SMC of your Mac
Otherwise its going take someone with deeper skills to fix your system.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Reseting SMC did not work. Is this problem related to Flexgate?
из
@soumitrokumar - Flex-Gate was a MacBook Pro issue, not the Air's as the ribbon cable was too short. Your issue is deeper within the logic board's backlight logic.
из
Добавьте свой ответ
DS Kumar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 873
