Updated with pics, what typ of bit fits screws on front speaker grill?
Kyocera Dura Force Pro 2, there are 2 screws below screen holding metal speaker grill to phone. They are a security bit of sum type, but I can't find a driver bit to fit them. Judging by the cap this bit is probably going to look like a socket more than a driver bit. There is a small gap that a thin walled socket could fit (maybe). I've bought every micro driver bit set I could find. Everything from jewelry repair to gunsmithing & no luck. Maybe a proper name of cap screw would help. Thanks for looking, any educated answers are appreciated.
Это хороший вопрос?
Оценка 0
2 Комментариев
@h8ermaker post some good pictures of those screws with your QUESTION Adding images to an existing question
из
@h8ermaker don't you just hate it when they use proprietary screws like this to keep us out? Anyhow, your image is still a bit hard to make out. Looks like some kind of triangular inside and I see one notch on the outside. Are there three notches on the outside or just the one that is visible?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Here are the guides for working on this. Please post a photo of the screws so we can identify them
Kyocera DuraForce PRO
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I have the Pro2 which differs a bit. I added sum pics as suggested, I'm just trying to gain access behind metal to clear away debris that is muffling microphone. Thx for your reply though I appreciate it.
из
Добавьте свой ответ
Bruce Simmons будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 178
