The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Why is my dryer is overheating..
I having the same issue with my electric dryer Kenmore elite. I have replaced the thermal fuse, thermistor, hi limit thermostat, and the cut off thermostat. Dryer still producing high heat even on the Air dry setting. I have cleaned out the entire interior duct work and venting inside the dryer and the connections from the dryer to the outside vent. I scrubbed the lint screen. I inspected and tested the heating element; nothing broken or shorting out. The felt seal around the drum is fine. The belt is intact and when the drum rotates the blower fan turns. I am LOST. I am thinking it’s the control panel. Advice??
Это хороший вопрос?
Счет 0
1 Комментарий:
Hi,
What is the model number of the dryer?
из
Добавить комментарий
1 ответ
so you've pretty much replaced all sensors, and cleaned it out right? And you're getting high heat even on a no-heat setting? Then it is definitely controller.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Nanette Thompson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 97
