4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
Facing No Service Freqently
Hi Team ,
i am facing No service Frequently ,
let me know if any solution available ,
the thing is i asked many technicians but they are not giving any guarantee instead of that they are saying that it may dead if they do any thing,
please let me know any possibility there to get it repair done ,because its gifted by mother since i am using this mobile from 4 years ,no repairers instead this only one issue,
Thanks in advance
Bharath.A
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
If you've tried resetting network settings or completely wiping the device and the issue is still persisting, then it is likely a failure on the hardware side and you should get a reputable repair shop to diagnose the problem. Usually this will be done by a professional under a microscope, and they'll be able to tell what the issue is and how much it'll be to fix(if possible at all). Back up your data and try to identify if it's software related first though, however if it isn’t, it'll be a bit trickier and more expensive to fix unfortunately.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
i Tried it several Times Liam ,But No use ,can you suggest anyone who will be able to resolve the issue ,
Basically i am from india ,if they will repair it, i can ship my mobile to there place
из
@avulabharath Here is a link I found through about 2 minutes of googling, however you could probably spend a little bit more time searching to find a better or faster service.
https://www.irepair.in/irepair-doorstep-...
из
Hi Liam Thanks For Your Information ... I will Follow Up
из
Добавьте свой ответ
BharathReddy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 90
