I replaced the clutch now it will not start cranks does not turnoveres
I replaced the clutch on 2004 rx8 6 speed
It cranks now but will not start.
Это хороший вопрос?
Оценка
0
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 45
any issues before the clutch change or just a routine change?
из jay
No issues aside from burnt clutch
из John Barrett
does it crank over at all the engine or is there no signs of life?
из jay
I know a clutch job can be quite involved depending on the vehicle but did you check to make sure everything was connected?
из Jesse Hooton
If it does not crank at all I would look at clutch safety switch. If it does not crank. Check to see if you have spark. And check to see if you have fuel pressure. Some times the wire running to fuel pump is near tranny. And can get pinched or cut while removing
из GKJarhead
