iPhone 11 carrier unlocked but only accepts one network
I picked up a used iPhone 11, seller told me it’s network locked so I figured that can be fixed by getting in touch with the carrier. Long story short, in about (settings) it shows that there is no sim restrictions. Called the carrier and they told me that they don’t lock iPhones.
when I try to insert any other sim, the network registers but throws me a “No Service” error. Sometime it shows one bar for a brief moment and then reverts back to no service.
its not a sim or hardware issue as the sims work in my XS and the 11 works perfectly on the one network. IMEI has not been blacklisted.
NB. Screen was replaced but it shouldn’t affect anything
can anyone tell me what it is? Anyone experiencing the same issue
Это хороший вопрос?
what carrier are you trying to use it on? I know some carriers require you to notify them that you're trying to change the SIM card from one device to another.
из Jesse Hooton
carriers here don’t require notification when switching sims as it works perfectly fine on my XS
из Lex Zahv
I hаd a similar іѕѕuе,
Fіnаllу I mаnаgеd to resolve thе problem.
Follow thіѕ guide hеrе: https://bit.ly/3elXoth
Hope thіѕ helps
из Justin Swart
