Windows 10 is a major version of the Windows operating system. It was released in 2015.
22вопросов Показать все
How to stop McAfee pop ups notifications on windows 10?
Hi, McAfee pop ups are coming time to time on my windows screen between the programs. My McAfee subscription has finished last month and I am facing MacAfee pop up issue. Can I stop it? Help me
Это хороший вопрос?
Оценка 8
5 Комментариев
Hi,
Have you tried uninstalling the program?
из
isnt that a virus
из
@ jacob muehlberg
McAfee is a 3rd party anti virus program (see list) that has the habit of notifying you when your McAfee subscription needs renewal and unless you completely uninstall it, because you don't want to use it anymore, they persist
из
ah ok i must be thinking of something different my bad
из
Jag vill inte ha skyltarna som kommer upp ta bort virus
из
Добавить комментарий
5 Ответов
Выбранное решение
In order to remove McAfee from your system you want to open windows settings then open the apps category, now in the apps and features tab scroll down until you see McAfee antivirus listed as an app now click on it and then click uninstall then select to allow McAfee make changes to your system and then follow the instructions on the uninstallation wizard (if there is one) to finish uninstalling McAfee.
Был ли этот ответ полезен?
Оценка 6
5 Комментариев:
I did not have the McAfee in my system, however, I had WedAdvisor by McAfee, this was the source of the pop ups. So scroll all the way down to see, if you have this installed as well, even if not McAfee. Uninstalling it did the trick for me.
из
Thank you! Thank you! Thank you! Finally the answer I needed to get rid of the annoying McAfee pop-up ads. I really appreciate your help with this - It worked like a charm and was easy to do!
из
The only McAfee app I can find in my Apps list is McAfee Security Scan Plus, and it is not possible to uninstall it - the Uninstall button is grayed out. There is no WebAdvisor in my Apps list.
из
Thank you, Tanja K. Uninstalling the WebAdvisor did the trick for me too!
из
worked for me too! So glad to see this, Thank you, Thank you
из
Hello there
there are many types of pop ups such as renewal pop-ups, alerts and notification pop ups, threat detection pop ups etc. Stopping these pop ups may result in trouble instead you should try to limit or change alerts settings.
if the mcafee subscription is expired then you should know how to stop mcafee pop ups using the method provided in link.
the reason you get pop ups from Mcafee even after uninstalling Mcafee is web extension and leftover files. when the program is removed but has certain leftover files or web extensions it might affect the web browser or system and in result it may give our annoying pop ups.
hope this helps your Question.
Оценка 3
7 Комментариев:
I've uninstalled Mcafee and still have pop ups. How do I stop them. You explain why I have them above but not how to get rid of them.
из
I love how no one has actually answered your question thoroughly 😅
из
C,ick Ctrl/Shift/Del to clear cache and cookies. That should do it!
из
I FOUND THE ANSWER. Search for the services app with the windows button and open it up. Even if you have McAfee uninstalled it will still show up in here as running! Stop the service, go into its properties and set it to disabled!
из
Check for WebAdvisor (by McAfee) in the installed programs. As it has a different name, I missed it at first, but uninstalling this as well could help. It was the source of the spam pop-ups for me.
из
Показать 2 больше комментариев
Оценка 2
1 Комментарий:
Thanks Mattias! Will the service stay disabled after restarting the PC?
из
Start-> Settings-> Apps, scroll down until you find McAfee and uninstall it.
If you want to disable pop-ups, you need to set the settings in McAfee and / or turn off all notifications. For notifications, click on the icon to the right of the taskbar.
Оценка 0
Uninstall McAfee software via windows setting. Still if you are getting pop up, remove McAfee extension and plugin. And another ways is to stop pop up is, go to setting > privacy and security > site settings and stop notifications from websites.
Оценка 0
Добавьте свой ответ
Thomas Clark будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 104
За последние 30 дней: 319
За всё время: 30,468
