The screen has a blue tint to it and no color adjustments.
Philips TV Model 55PFL5402/F7 . Reset to factory settings no help. Unable to change color with Blue, red or green on screen controls. What is the TVs problem??
Это хороший вопрос?
Это хороший вопрос?
Jeff possibly the backlight strips. All LED’s start out as Blue and are then coated. If that coating fails you get more blue/purple hue. Post an image of what your screen looks like so we can see what you see. Adding images to an existing question
You would have to replace the backlight strips to remedy the blue.
Был ли этот ответ полезен?
Posted the TV image. Thanks for response
Now that is blue. this is more than just a blue hue from bad backlights. Dang, it's blue:-) Anyhow this is a case where I would at minimum switch out the T-con board and see if that corrects it. Of course, you did set your menu properly and made sure your adjustments are okay.
try auto picture that,s how i got rid of the blue color but only 2 setting,s have no blue color but it work,s
За последние 24часов: 17
За последние 7 дней: 132
За последние 30 дней: 597
За всё время: 23,566
2 Комментариев
My aunt's 55” Phillips looks exactly like the image above. I tried all of the different picture mode settings and firmware update, but the only adjustment that made any difference was to turn the blue saturation as low as it could go. Now it's a bit too red and we're off to buy a new TV.
This was one of those 2018 *Black Friday* Walmart deals with a too good to be true price.
из David Orino
Same things has happened to ours, also a Black Friday deal a few years ago. :/
из Tasha Dale
