Wont turn on or charge
I try to turn it on and it won’t do anything and when I try to charge it it won’t
Это хороший вопрос?
Это хороший вопрос?
@brendankkkk could be an issue with the charging cable , the charger or the charging port. Try a different charger/cable. Clean the charging port with a few puffs of compressed air or similar. Check the port for any broken or bend pins. If all of that won’t make a difference, replace the battery next. Once you have that done see what you get. Check the motherboard for any damaged looking components and post some good pictures of your boards with your question so we can see what you see. Adding images to an existing question Use these guides to work on your Boom UE Boom 2
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 24
