2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
MBP reboot loop even after ssd replacement
My 2012 MBP (10,1) Retina recently started rebooting out of nowhere with the ‘your computer restarted because of a problem…’ error. I chalked it up to maybe the hard drive finally going. Replaced it with the OWC Aura Pro 6G ssd seen here: https://www.amazon.com/dp/B07NZ8RDZH/ref...
I then installed a fresh copy of Catalina and I’m still getting the same error. It will run for maybe 20 minutes, then go back to the reboot loop again.
I am now at my wits end. Any help would be appreciated.
Это хороший вопрос?
Счет 0
2 Комментариев:
What does the onboard diagnostics tell you? Reboot your system and press the D key to enter. Did you get any errors?
You may need to go to an authorized Apple repair shop to run the service version of diagnostics as Apple messed up the onboard diagnostics in some versions of firmware so the onboard version won't work.
Reference: Mac startup key combinations
из
I may have to take it in. Holding down D when booting up takes me to online recovery.
из
Добавить комментарий
1 ответ
@scottjohnson - Ask nicely as some shops follow Apple's guidelines on repairing older systems Mac products obsolete worldwide. Just ask for them to run the diagnostics only make sure you take note of the error/s. Some independent shops may have the needed service diagnostics.
FYI - Apple Stores won't help you.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
@danj thanks Dan, appreciate the help!
из
Добавьте свой ответ
Scott Johnson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 117
