Dear Brad!
Please help me about my problem, what's maybe just partially bit offtopic, because I have a Lenovo phone, not an iPhone. I searching
internet wide, as my skills and time let me do. This community are the closest. So, there
is my situation:
I have a Lenovo a760 Ideaphone. After one week usage display begin to vibrating, similar
to a lighttube goes to die. And the screen's border lighter, and inside a big dark spot.
And all screens transparent, so i can see on actual screen the before screen's shapes.
Now i seen on my homepage, and i can see my before used browser window's shape. I
hoped before I founded the community, this just a contact issue between the display, and
the panel. Im in Hungary (No support for IdeaPhone). Some suggestion from you?
Below image from boot screen. Normally all of screen must be black, excluded Lenovo logo, and slogan. All others seen is are remaining from the earlier session.
https://lh5.googleusercontent.com/F4ljJc...
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
3 Комментариев
it could be a short on the LCD connector and you've just blown another screen :-( if you put the good screen back on the good motherboard what happens?
из pollytintop
Okay, so you for sure have one phone where the backlight is working and the screen lights up, correct. You disassembled that one and replace that LCD with the one from the phone where the backlight is not working and have the same result. Now I get confused when you said you "took a good LCD assemble, hooked it to the phone and no light." Which phone did you hook it up to? The one that was working before, or the one that did not work? Sorry, I may make it sound more confusing than it really is....
из oldturkey03
Oh, I have the same :|
The lcd assembly was wrong, and the + and - of backlite leds was shorted a few times if I pressed a top right corner of the screen. After a lock/unlock the backlite returned to life, but once again it didn't. I swaped the screen, but that does not work too. No backlite, and I have no idea how to fix it, it's mainboard problem now :|
из Anri
