Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794вопросов Показать все
MacBook won't repair itself and only loads halfway
Hi I asked a question before but I got the model and year wrong so figured I would post a more accurate question. my macbook has worked fine for years but now only loads half and shuts off. also when I go to do self repair it says it cannot repair itself. how would I go about fixing this problem?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из
Добавить комментарий
1 ответ
Could be several things.
Try a Safe Mode boot by holding down the Shift key on start up.
Next try a PRAM reset.
How to Reset PRAM or NVRAM
  1. Power off your Mac.
  2. Press your Mac's power button and then hold these four keys at the same time: ⌘ + option + P + R.
  3. Continue holding the keys until your Mac restarts for the second time. On older Macs, the chime will sound upon restart.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Joshua будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 7
За всё время: 32
