1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
189вопросов Показать все
Fan spins for roughly 5 seconds and keeps restarting. Short somewhere?
Hi guys,
I have a MacBook mid 2012 logic board 820-3024
The fan spins when the power adapter is connected then keeps restarting the fan spin process after about 5-6 seconds. I’m convinced there is a short some where; I have the schematic heat gun multi meter iron etc so am ready to start diagnosing & fixing it.
Anybody come across this issue ?
Where abouts should I start measuring resistance values etc.
I know old turkey is good with this stuff. Any help will be greatly appreciated :)
I might even buy you a beer !! Haha
PS - MAGSAFE ADAPTER LIGHT STAYS GREEN
Update (08/15/2021)
Board is 820-3023-A… my bad
Это хороший вопрос?
Оценка 0
2 Комментариев:
What happens when you remove the SSD?
Follow this guide MacBook Air 11" Mid 2011 Solid-State Drive Replacement to take it out. Does it now boot up with a flashing Question Mark in a folder icon?
из
Hi mate,
Removed all peripherals mousepad speakers ssd etc ..
I/O board is good. Backlight fuse good.
It’s a power issue for sure.
Thank you for your reply :)
из
Добавить комментарий
1 ответ
Time to replace the logic board then MacBook Air 11" Mid 2011 Logic Board Replacement as the logic is within it.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Really ? No diagnosing to find the short ? Do you have experience in logic board fault finding ?
из
@Nathan Pelling - Board level diagnostics is not something you can do remotely. It would be like a doctor trying to guide someone remotely doing brain surgery!
Then you need to look at the costs, a 1.6GHz i5 4GB board can be gotten for $230 USD (Apple P/N 661-6071) which in the end would be cheaper!
из
Добавьте свой ответ
Nathan Pelling будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 69
