Repair guides and support for cassette players.
85вопросов Показать все
Cassette play button/slide rstuck
Hi everyone, I'm new to cassettes and the culture surrounding it but recently I came across an old JVC play / record deck but whenever I tried to play something on it it would spin for a bit and soon it would stop and start to emit a high pitched noise. I tried fixing it but when I put it back together the play/rec slider was jammed up. I can't seem to find what caused it, if anyone knows anything about either of these problems I'd greatly appreciate the help.
edit: I'm not sure on the terminoligy, it's a handheld device, not a deck
Это хороший вопрос?
Оценка 0
2 Комментариев
Hi,
What is the model number of the player?
из
Hey, it's a mk 100
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi,
Here’s the service manual for the recorder.
It has the assembly layout, the schematics and adjustments etc.
Hopefully it will help you find the problem
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Joshua Choi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 117
