Corroded battery compartment Polaroid Automatic 100
Is it possible to replace the battery compartment/wiring harness for a Polaroid Automatic 100? Are replacement parts even available? In my unit, there is corrosion, and the Negative wire terminal has broken off (see attached photo). I see a single Philips screw that apparently secures the plastic battery holder in place; but I don’t see a way to remove/replace corroded wires and harness. Any advice or help would be greatly appreciated
Это хороший вопрос?
