The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
Fans won't come on now
Xbox360 used to have three rings now gone, I know have two rings. It can't be getting hot because the two ring come up straight away and the fans don,t turn on and the disk tray won,t open either. Help
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
Kent, check on here for a good explanation of the error codes and how to obtain more information from your console. The error itself can be caused when the CPU or the GPU are overheating as well as a bad solder connection of the Ram chip. I guess the only way to fix it would be to reflow the board either by a professional or you could try this. The only other thing I can think of is to use the RROD kit from here. Hope this helps, good luck.
Xbox 360 Red Ring of Death Fix Kit Изображение
Инструкция
Сложность:
Сложно
45 minutes - 1 hour
Xbox 360 Изображение
Инструкция
Reflowing Xbox 360 Motherboard
Сложность:
Сложно
1 - 3 hours
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Kent буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 197
