1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
No image on internal display
Hi all,
MacBook Air displays no image on internal display but will via display port to external display and works fine.
There is no evidence of any liquid or visual bad components front and back of MLB. LVDS Connection is also fine on MLB.
I have replaced the internal display but the issue is still present.
I would like to repair the MLB via micro-soldering but im not sure what component may be at fault, any guidance is greatly appreciated.
Это хороший вопрос?
Оценка 0
2 Комментариев
Lets make sure we've isolated the issue down first. Using a flashlight aimed through the Apple logo do you see a faint image of your desktop and its icons?
из
Hi Dan, there is no image when using flashlight. Thanks for picking this up.
из
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
Follow this guide MacBook Air 13" Mid 2012 Display Assembly Replacement Stop at Step 3, then jump to Step 22 carefully disconnecting the cable. Now hold the cable end so you can take a picture like this
Make sure you are as tight as this shot and in focus (you may want to add some light) Then follow this guide to post the pics Adding images to an existing question so we can see things.
MacBook Air 13" Mid 2012 Display Assembly Изображение
Инструкция
Сложность:
Сложно
45 minutes - 1 hour
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Harry Nicholson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 63
