What does F11 mean?
Tried unplugging, and restarting.
Это хороший вопрос?
F11 is an indication of a communications problem.
Communications cannot be sent correctly between the machine control board and the motor control board.
Here are some possible causes:
Loose wire connection at either the machine control board or motor control board.
Machine control board failure
Motor control board failure
Door lock
Motor
Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the
Hard Reset
procedure below.
In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
Unplug or turn the circuit breaker off for 10-20 minutes.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Without a model number I am unable to provide you with specific information. For further assistance resubmit your question with the complete model number.
Был ли этот ответ полезен?
Hi, you seem to be an expert, and I thank you for sharing you experience.
What would be the Hard Reset for a Whirpool GHW9400PL1 washer?
Many thanks
Leonardo
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 184
