Dropped Printer Solid Red LED, but cycles Green/Red when cord is moved
AC plug loose Red LED momentarily cycles GREEN/RED when cord moved
Это хороший вопрос?
Это хороший вопрос?
@dwr2021 you mentioned that “AC plug loose “ so now when you move it, it appears to loose contact or shorten things out. I suggest that you try to disassemble your printer and check the AC plug out. Make sure that it is still properly mounted and that the board looks ok with any cracks etc. Post some images of what you find with your Question. That way we can see what you see. Adding images to an existing question
This video should at least get you close to it. if you need more assistance, use this service manual Samsung ML 2570 Service Pdf
Был ли этот ответ полезен?
Thanks for the advice. I did disassembly, but saw no issue. I re-assembled, bought a new power cord, but still no joy. I picked a $30 Brother printer. I'm thinking of just donating the ML-2510 and the new toner I tried as last resort.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 28
