CDMA версия четвертого поколения iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. 16 или 32 ГБ памяти / Модель A1349 / Cовместимость с CDMA.
Вопросов 20 Показать все
Logic Board Rubber Bumper Location?
I replaced the display assembly this weekend, but when I was attempting to reinstall the logic board (step 21 of the guide, in reverse), a small rubber bumper came loose from 'somewhere' on the board (I think).
Here's a picture of the bumper (with the broken screen as a backdrop to give you a sense of proportion). Can somebody identify where it belongs? It's seldom good when you've got parts left over!
Это хороший вопрос?
Оценка 3
Добавить комментарий
Ответов (4)
Выбранное решение
It goes on top of the Logic Board, under the two Front Screen Flex Cables. I have seen a couple of iPhone 4 without this installed or just missing and they functioned perfectly.
Был ли этот ответ полезен?
Оценка 8
2 Комментариев:
That did it!
из
That was a huge help. Thanks!
из
Also, notice there is a thick and thin side to the bumper, and the thin side should be on top, or toward the back panel.
Оценка 2
That little plastic bumper folds over the top of the logic board assembly where the Digitizer ( Front Panel) cables come up and over. If you look close at the bumper there is a small grove that is the same size as the boards thickness. Its just there to protect the Digitizer's cables from the rough surface of the logic board.
Оценка 2
1 Комментарий:
Thanks for that info... Super helpful
из
what would happen if you were to put this on the wrong way
Оценка 0
Добавьте свой ответ
Matt Strange будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 7,434
