W/D makes noise when off!
Okay, I have a crazy problem, but here’s some background info. Recently moved into 2nd floor condo and had an LG Washtower installed in kitchen alcove/closet. All of the w/ds here are in the kitchen closets and there is a drain pipe and vent to outside in wall in back. The water hoses are 10’ steel and there is also one that attaches to dryer (as it provided steam, but never tried it). About 4” of space on either side and room in back for semi-rigid aluminum vent duct. There was trim attached around the opening, so there’s only an inch on either side when looking at it. The way this was installed it impossible to move unless I hired some strong men to carefully pull it out as the pipes for the water are overhead with only a couple inches clearance. Now here is my crazy issue. Occasionally there is a quick “pssst” noise coming from the back. It occurs at random and maybe from 5 to 20x a day. It lasts a second or so, like someone quickly pressing an aerosol can, and sounds like that too. Any takers? I feel like I’m going crazy! At first I thought it had something to do with the roof vent that it’s connected to, but it really doesn’t sound anything like that. It kind of sounds pressurized?! All thoughts and ideas are appreciated!
Это хороший вопрос?
2 Комментариев
Hi @kitkat451,
What is the model number of the W/D combo unit?
have you tried turning off the power (disconnecting it) from the appliance and check if the noise still occurs.
If it is plugged in somewhere where you can't get at it then perhaps you can trip the breaker or remove the fuse for the W/D in the power box for the premises.
usually most W/D require a separate feed from the power box and are not on the same power feed as other power outlets. It should be marked in the box.
из jayeff
Hi @jayeff,
It's model WKEX200HWA. I haven't turned the electric off yet, and yes, unfortunately at the breaker b/c I can access absolutely nothing behind the machine. I was doing some reading this morning, and wondering if the inlet valve could make the noise with sudden increases in water pressure. I hear water hammers frequently in my area of the building.
Just wanted to add that someone either below or next door was running their water 2 separate times this morning. The second that the water shut off, I hear "psst" coming from the w/d area (lasts only a second every time).
And yet another edit, lol; just noticed when a neighbor opened their water (tap, d/w, or washer, can't tell), the sound occurred here again. So apparently water turned on or off.
из Kate
