MacBook Air (early 2015): fix broken LCD backlight power
My sister spilled apple juice over her Early 2015 Macbook Air, and failed to switch it off immediately…
I managed to disassemble and clean it by following these excellent instructions so it at least boots again, but the backlight is broken. When pointing a flashlight to the display, it looks as if the LCD itself is not damaged afaict.
Searching the internet I found hints that it might be possible to fix this issue by replacing a fuse o a FET or a driver IC. Is this correct? Any hint where these components are located, and what are their specs? Or would it be better to replace the entire logic board?
Thanks in advance, Albrecht.
Edit: some (bad, created using a mobile) photos of the main board:
- the cleaned mainboard after re-installing. I noticed corrosion in two places, indicated by the red circles:
- corrosion in the right location, close to the AirPort, before cleaning:
- same place, after cleaning:
- in the left location, close to the display connector, after cleaning (sorry, I don't have a photo with the corrosion, i.e. before cleaning):
Apart from the broken panel backlight, the systems seems to be fully operational. I could log in, connect an external DP monitor, and test the following:
- OK are: keyboard (checked every key), keyboard backlight, trackpad, both USB ports, external monitor out (DP), Wifi, Bluetooth, internal speakers, headphone, microphone, camera, SD card reader.
- The battery is detected and charging (I guess I have to reset the SMC and re-calibrate it, though).
Это хороший вопрос?
4 Комментариев
@albrechtd that depends on your capabilities and tools as well as what may have failed. Besided checking that your backlight is not working, what else have you checked? Post some good pictures of your logic board with your question. That way we can see what you see and possibly offer some solutions. You do recognize that soldering very small components requires some pretty good skills and tools. Adding images to an existing question. Check the LVDS connector since it loves to corroded on the contacts
из oldturkey03
Hi @oldturkey03, first, thanks a lot for your reply!
Well, I know that my skills are actually limited, although I'm an electrical engineer with some experience in hardware design and prototyping, have access to semi-professional SMT soldering equipment and know how to use it (and a sip of Scotch will calm down my trembling fingers…). IOW, I think I might be able to replace a larger component with few terminals, but of course no TSSOP.
I added a few (bad) photos and a summary of my tests to the original question as you suggested.
Thanks, Albrecht.
из Albrecht
@albrechtd I am certain but do have to ask. You did clean the bottom of this board too, correct? Email me for further details that will go beyond what I can do on here. My contact address is in my profile
из oldturkey03
Hi @oldturkey03, thanks again! Cool, the schematics, placement & your instructions will definitely be *extremely* helpful! I'll have to leave for a business trip for the rest of the week this afternoon, so I'll performy your checks this weekend and get back to you.
And, yes, I cleaned the bottom of the pcb, too… ;-)
Thanks, Albrecht.
из Albrecht
