How do I unlock CL on LG
How do I unlock CL on LG Inverter Direct Drive True Balance Model Number WM3900HWA ?
Это хороший вопрос?
Счет 7
10 Комментариев
My LGWasher say CL lock
из
@Ilene Barton
What is the model number of the washer?
из
non of the above worked
из
@michael1950
из
How do I turn off cl code model # WT1101CW
из
Показать ещё 5 комментариев
Добавить комментарий
10 Ответов
Выбранное решение
Hi @crbc
Turn on the power to the machine and then press and hold the Rinse + Spin buttons (both together) for 3 seconds to either activate or deactivate the Control Lock feature.
Был ли этот ответ полезен?
Счет 5
20 Комментариев:
This is a true balance top loader how to turn off child lock
из
@Arlene Jackson
из
This didn't work for me... have a 14kg top loader.... thanks for the suggestion though.
из
@relax
из
On my top loading super inverter LG washer I just had to press the child lock button for three seconds. I didn't notice but it actually says "Child lock" in very small letters.
из
Показать ещё 15 комментариев
Hi @Barb Wandsnider
Press and hold the soil level button for 3 seconds during the wash cycle to disable the child lock.
Here's the section from the user manual that explains how to enable and disable the feature.
Счет 3
10 Комментариев:
I held down the rinse & spin button for 3 seconds. It released the control lock.
из
My question: why does the manual not describe how to deal with this error code nor even list it in the error message section??? Thank goodness for Google. Press and hold the water plus/child lock button worked for me.
P.S. I bought this machine 8 years ago. NO other service issues 😌
из
@maryalicee66424
The CL code is NOT an error code.
It is usually described in the user manual under the features i.e. Control Lock or Child Lock and is there to inform whether the lock has been enabled or disabled, usually done by the user of the machine
из
My panel shows child lock and CL. I tried pressing rinse and spin for more then 3 seconds it does not work. Please advise.
из
@florence65414
Not every washer uses the same button sequence to enable/disable the Child lock feature.
из
Press and hold the CHILD LOCK button for 3 seconds
Счет 1
1 Комментарий:
Thanks! Worked on model number WM4370HWA
из
None of the above worked, probably because my panel is different. Then I noticed on my LG the Half Load and Energy Saver had an note below them: Control Lock.
I pressed both simultaneously and the frustrating CL was cleared.
Счет 1
This worked on my LG model, which has a similar control panel to yours:
For front-loading washer dryer combo “Inverter Direct Drive True Balance” LG model #WM3499H*A:
1) Once LG machine is powered ON:
2) Go to the right touch-screen panel, press and hold “Pre-wash + Delay wash” buttons simultaneously for 3-5 seconds. This will turn OFF the CL (control lock/child lock). You’ll hear a little jingle when the function is processed.
3) Similarly, pressing this combo simultaneously again for 3-5seconds will turn back ON the CL .
Hope this helps!
Счет 0
I pressed both rinse and spin button simultaneously. But it doesn’t work. What if the rinse button is spoilt?
Счет 0
1 Комментарий:
Hi @shuxiantan,
What is the model number of your washer?
Not all LG models use the same lock/unlock control buttons.
If your machine does require the spin + rinse buttons to be operated, then if the rinse button is faulty it will have to be replaced or somehow bypassed to disable the CL code
из
Help not working top load lg inverter direct drive
Счет 0
1 Комментарий:
Hi @annahernan51976,
Is it showing a CL message or light?
из
Hi @lakjayaran59503
Not all LG washers use the same set of buttons for the CL function.
To activate/deactivate the Child Lock (CL) feature in your model, press and hold the Beeper button and the Rinse button (both together) for 3 seconds.
Счет 0
Hi @gailm86723
To activate/deactivate the Control Lock (CL) feature in your LG WT8400CW model washer, turn on the power to the washer and then press and hold the Deep Fill button for 3 seconds.
Счет 0
3 Комментариев:
How to deactivate a child lock on washer MEZ64580704
из
@mapalla
Please confirm the model number of the washer as the number you posted gives no results?
из
WM8900HBA Is my model number. I tried the combo pre wash and delay wash. It did not work
из
Hi @mgurganus1
To activate or deactivate the CL (control lock) feature in an LG WM8900HBA washer, turn on the power and then press and hold the Steam button for 3 seconds.
Счет 0
Добавьте свой ответ
Chris Cargen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 14
За последние 7 дней: 83
За последние 30 дней: 520
За всё время: 58,950
