Repair guides and support for televisions manufactured by Panasonic.
3 blinking red led fault code
Panasonic TX-P42X60B
I am trying to get the panel for this TV as I think it is the power panel that is fault
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@electric151 the 3 blink code for your TV model is most commonly caused by a bad A-board. That is your main board. Of course, the 3 blink code is not listed anywhere. So, it’s a bit of a gamble. I’d check the power board output to the A-board on the connector. Check to ensure all voltages are present as listed on the print on the board. IF they are, then you pretty much should try to replace the A-board.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Alistair Dunn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 134
