Why is my dryer not hot enough?
I have an old Maytag gas dryer model DG9800. It takes 2 hours to dry a regular load, with some parts still being damp. I checked the vent from outside and the air seemingly went out fine. When the dryer was running, I opened the door to feel inside, and it was just warm (95-100 F). I noticed the flame went on, stay there for a few minutes, then went off. Such happens a few time during the drying process. I assume it would be hot even if the vent was clogged a little bit, so I think it is due to that the flame went off too soon, before the temperature reached the target. Is this correct, and if so, which part could be faulty? Thanks!
Это хороший вопрос?
1 Комментарий
Thanks to @stressmaster @jayeff ! The symptom of bad ignition coils in the youtube video is the same as mine. Actually my dryer’s wires are connected to the coils by tape due to a broken part. I’ll re-attach that first. A bad cycling thermostat could show the same symptom, and I’ll check that too.
из Jay
