Can you replace the battery?
The pixel buds disconnect whenever they are removed from the case. I think the batteries are bad. Is it possible to replace the battery?
Это хороший вопрос?
Это хороший вопрос?
Hi,
Here’s the Ifixit Разборка Google Pixel Buds 2 guide which shows how to open the ear buds.
The guide was only to show the internal components and is not intended as a repair guide because of the damaging way in which the earbuds have to be opened.
The battery is a Varta CP1240 A3 (supplier example only) if you think that you want to try and replace them
Был ли этот ответ полезен?
If anyone is attempting this repair, I had good results with using a pair of pliers and gently applying enough pressure to bend the plastic slightly to crack the seal with minimal damage to anything else
I don't believe it is possible to open these earbuds without damaging the casing. Therefore, you cannot replace the battery.
За последние 24 часов: 2
За последние 7 дней: 22
За последние 30 дней: 78
За все время: 9,778
1 Комментарий
I'm not seeing replacement batteries for the buds themselves, and the process looks pretty destructive. These aren't made to come apart.
из brandon k
