Transmission hesistating / sluggishness when engine is hot
i have a 2004 Honda accord v6 3.0 sedan. My transmission does not pick up well when the engine is running hot but when the car is cold it works perfectly fine. does anyone know what could be wrong?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Did you try searching for Honda Accord forums? Owners join and share problems and answers.
из
Добавить комментарий
1 ответ
It appears there was a recall issued in the US for the 2004 model year for transmission issues due to insufficient transmission fluid flow. You can check here if that recall as ever performed. Again, this is if you live in the US. https://www.nhtsa.gov/recalls
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Adegoke Olusola будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 24
