A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Goes into a sleeplike state
I have a Macbook that I’m having trouble figuring out the issue. When using applications such as the browsers the display just goes dark. Taping the trackpad, keyboard, and power button do not wake it up. Have to hold the power button down then turn the computer back on again. I even had the computer shut off and when I turned it on it showed the low battery indicator saying it needed to be plugged in, in the middle of the screen. I thought that was weird because the battery was at 92% last I looked, when I plugged it in it turned on and was at 92%. I checked the battery status, it says it is normal and only has 383 cycle count. I did scan for viruses and found there are some infections, but from prior experience I haven’t seen infections cause this. And the Mac does have High Sierra if that matters.
coconutBattery results
Это хороший вопрос?
Оценка 0
4 Комментариев
Let’s double check things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
This sounds like a weak battery
из
@danj Is the app free? Or do you have to pay to get the info?
из
@chryse CoconutBattery is free. Go to the website Dan linked and click "Download v3.9.7", then go through the installation instructions.
из
@danj Posted :) and I figured it could be a weak battery since the computer is 5 years old, but usually with that I've seen it say to service in my experience.
из
Добавить комментарий
Ответов (1)
Выбранное решение
Well, the battery is well used with 383 cycles, but cycles alone is not the only measure, age also comes to play and looking at the design capacity it’s getting close to the end of offering much time on battery alone.
I would recalibrate the battery to see if that helped, otherwise it’s time of a new battery.
Reference: Calibrate & Maintain Your MacBook Battery For Best Performance
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks, and I'm probably gonna go with the battery being bad then. Tried calibrating earlier and that didn't resolve it.
из
Добавьте свой ответ
Chris будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 30
