Works ok plugged in. Only at very high volume not plugged in. Cuts out
So these speakers are $500. I already had to have it replaced after like 2 months for a different issue. I barely use the thing. Yesterday I go to use it unplugged (which is the whole point of it) and even when I start it up the usual noise it makes starting up was replaced by a strange like click noise. The blue light is on like it’s normally operating and shows battery is fully charged. The only way it will play sound is when I turn it almost all the way up then it cuts in and out and sounds horrible.
Plugged in it sounds perfectly fine. You would think battery ? But it shows it’s fully charged and it wouldn’t effect the noise it makes when it starts up right? I wrote to the company but guarantee they won’t do anything past their short 6 month warranty window. I mean 6 months?
I did everything possible. Factory reset. Tried different devices. Tried Bluetooth and aux cord. No matter what same result. I’m so mad this thing might be broken. I can’t afford to replace it. I’m on disability and was a gift that I enjoyed so much. I took good care of it for that reason! These new modern stereos and stuff they only have like 3 things possible to try and fix. It drives me crazy.
Это хороший вопрос?
