The Lancer is 4 door sedan or 5 door hatchback made by Mitsubishi. The standard model include engine sizes from 1.5-2.4 liters, gasoline or diesel. Transmission options include automatic, standard, and CVT.
13вопросов Показать все
My rpms keep going up and down but no check engine light
I have a 2017 Mitsubishi Lancer, my rpms keep going up and down but no check engine light. It just started 2 days ago and it doesn't happen all the time. I took it in and they can't find a code on what's wrong. I'm confused on what's going on with my car
Это хороший вопрос?
Оценка 0
1 Комментарий
Clean out air intake throttle body with cleaner. I did this and fixed it for me. You can youtube it easy to do!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Look for a vacuum leak anywhere after the MAF sensor
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Amber Rasmussen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 215
