IdeaPad Z560 — третий ноутбук серии Z, выпущенный в 2010 году. Модель 0914.
Is it possible to replace the complete body
Hi,
Complete body is broken. Need to know if possible to change complete body.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
You should be able to.
Here’s the hardware maintenance manual for the laptop.
This details the necessary pre-requisite steps and then procedures to remove/replace all of the components from the laptop.
On p.72 -77 there is a parts list which will help you to find the necessary case parts:
base (Item #18 - part #31044218)
upper assembly (Item #4 part #31044216)
lid (Item #6 - there are 4 part # depending on type, part # 31044223, 31044224, 31044340 and 31044341 - usually the part number can be found somewhere on the part itself it you wish to verify which one you have.
thermal door (Item #22 part #31042374).
Search online using the part number only in the search box of your browser to get results for suppliers that suit you best.
Был ли этот ответ полезен?
Счет 2
It’s certainly possible, though it may be difficult to find parts for at this point, since this machine is 10+ years old. I usually recommend checking with lenovo for part numbers, since that helps make sure you’re getting the correct parts. They will often have pictures to reference. I didn’t see the Z560 in this list but it may be identifiable using the exact model number or serial number if you have those.
https://support.lenovo.com/us/en/partslo...
Счет 1
Добавьте свой ответ
Bal Mukund Patel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 21
За всё время: 568
