Is this look like a bad screen or can I check the cable?
This machine was given to me by someone who was scrapping the ones they cannot fix themselves from someone who retired it due to old age and this issue. It's average and a few years old with some of the RAM stripped (as well as the SSD), so it's gonna need some help. Normally this person tries but this machine was too needy for them to fix so I got it because they know I can deal with needy systems. I can kind of see why having an 8250U. This isn't a bad chip, but it's also on the lower end even being 8th gen 4C/8T.
I was told it may have a unknown BIOS password but it's clean :-). I was just going to use it for parts otherwise but knowing the BIOS is clear makes it potentially fixable. I'm just going to replace the keyboard due to the fact several keys are shiny, one of the domes are missing and the scissor hinges are missing.
Is this look like something I can reseat the cable on, or am I going to need a new LCD panel/used assembly?
@oldturkey03 it won't work :(. And it's IVO so it has that cursed SV panel. I'm dumping the assembly and going to a normal IPS panel.
Keyboard is swapped out. Different part numbers but thankfully on these it doesn't matter since the PRIV keyboard can be interchanged on SV delete machines and factory non-SV.
Это хороший вопрос?
3 Комментариев
@oldturkey03 @danj
Pretty sure the screen is toast but what do you think? I can see about replacing the cable but it may be futile.
из Nick
Screen bleed? The buttons can be replaced easily.
из NR26
@nytryder26 It's missing a rubber dome so I need a keyboard like it or not. That said I have a SV keyboard I can move F2 to and quickly replace it.
This is a non SV notebook and will stay that way. The key is inert if you delete it so I shouldn't have an issue putting a SV keyboard on a non SV notebook.
из Nick
