Self-priming automatic electric pumps with helical gears, produced by Marco.
UP12/E-LOBR for ATF oil coolig system?
Hello,
I,ve question is good option to built ATF oil cooling system for cooling electric motor with this pomp ? how long can this pomp work, and can i control flow parameter by the SCS or by simple valve ?
Это хороший вопрос?
Счет 0
1 Комментарий
Hi @bedkowski ,
Perhaps @teof knows. You may have to wait for a response as this is a worldwide forum and different time zones means that there may be a delay before getting a reply. Hopefully not more than a day or two.
Moderator.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Dear @bedkowski, please write to export@marco.it for an analysis of your requirements.
Choosing the right pump is a matter of knowing the required flow, pressure and working cycles and our commercial department can help you with that!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Bartek буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 171
