It will sit for a couple of days and will not crank why is that
It will sit for a couple of days and will not crank why is that Battery is Dead Could it be one of the fuses
history of the car and what we have done
the car is a 2000 chevy cavalier
it has aftermarket cd player that stopped working thats the only aftermarket device in there.
we have replaced the battery and connectors and starter and alternator and yet when it sits a day or two then the car is dead and have to jump it off after the initial jump off then drives fine. but we cannot figure out what is draining the battery dead we even thought it was a bad new battery and replaced the new for a newer one yet still does it
Это хороший вопрос?
8 Комментариев
How old is the car battery and are there aftermarket devices installed that draw current?
из F Dryer
the battery is last year and yes but it dont work and
из Steven wright
i was wondering if it ccould be one over the Fuses
из Steven wright
What aftermarket devices are plugged in/hardwired? Leaving adapters plugged into the power outlet or incorrectly hardwiring electronics may draw battery current and eventually discharge the battery. Be sure main battery connections aren't corroded and loosely connected. Powdery blue deposits are from battery venting acid, eating away copper wires under insulation. Cleaning requires warm water and baking soda to dissolve and neutralize dried battery acid with water rinse.
из F Dryer
@notbroken the car is a 2000 chevy cavalier
we have replaced the battery and connectors and starter and alternator and yet when it sits a day or two then the car is dead and have to jump it off after the initial jump of then drives fine. but we cannot figure out what is deaining the battery dead we even thought it was a bad new battery and replaced the new for a newer one yet still does it
из Steven wright
Показать 3 больше комментариев
