14" display with Intel Core i5 business laptop, released in 2012. The full model number is R940-S9421.
Вопросов 6 Показать все
I have some issues after I installed caddy hard drive
Hello, I am having issues after installing caddy disk hard drive in my laptop because I accidentally broke my hard drive connector while opening.
Another issue is that usb keyboard is not working with laptop (laptop keyboard is damaged)
Now when i turn it on black screen appears saying
Intel(R) Boot Agent GE v1.3.81
Copyright (C) 1997-2011, Intel Corporation
PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. insert system disk in the drive. Press any key when ready. . . .
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
Hi @zain1 ,
It may be that it can’t detect the HDD due to the broken connector and since there is no bootable CD or USB inserted it moves to the last option which may be boot from PXE which is boot from a network drive connected via the LAN (Ethernet) port, which most home users wouldn’t use
Get into BIOS and check the boot priority settings and make sure that the internal HDD has 1st priority. To get into BIOS press F2 on startup when the Toshiba logo is on the screen.
Disable or remove the PXE boot option in BIOS (save the changes when exiting BIOS). After restarting, if it can’t detect the HDD there will be a message saying “insert system disk in the drive. Press any key when ready. . . . indicating that there is no operating system i.e. Windows, Linux etc found in the laptop.
You may have to get the connector fixed first before it will boot from the HDD. Is it the connector on the HDD or the motherboard? It should still boot from a bootable CD or USB but even if it does you still can’t access the HDD because it is not being detected.
Just verifying that you removed the battery before doing any other work inside the laptop?
Был ли этот ответ полезен?
Оценка 2
17 Комментариев:
Yup I removed the battery before opening it
Actually it was the connector from mother board that was Broken by me accidentally.
So I placed caddy with hard disk in place of CD ROM
из
@zain1
OK
Just trying to eliminate an electrical problem why the USB keyboard is not working when asking about the battery. Laptops aren't disconnected from any power when they're turned off. There are sections on the motherboard that still have power supplied from the battery. The Power On switch is not a power isolating switch. using tools and slipping or even touching components can damage them if there is power still connected to them
Plug a USB mouse or mobile phone into a USB port and check if the mouse's laser light turns on or if the phone shows that it is charging.
If not then there is a power supply problem on the USB ports.
Get into BIOS again and go to General > USB and enable USB Legacy support if disabled. This should allow you to use the USB keyboard even though there is no OS loaded but maybe not. I don't know Toshibas that well
If Windows is loaded when you get the HDD working OK then if the USB keyboard still didn't work, check in Device Manager > USB Controllers > USB Root Hub (all of them if more than 1)> Properties > Power Management > the setting that allows Windows to turn off the USB port to save power and make sure that it is "Unchecked"
из
Yess i checked it. It was only the keyboard that was not working otherwise usb is working on it
из
@jayeff bundle of thanks sir❣️
из
I have a similar issue however my laptop isn't picking up the hdd in the bios
из
Показать 12 больше комментариев
Добавьте свой ответ
zain будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 736
