The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428вопросов Показать все
My xbox turns on then instantly off.
It has not water damage, psu issues, it has great ventilation, good power cord, and absolutely no reason to do this. It was running fine unplugged it for a day or two and came back to hit the power button it made the power up noise but no shut off noise, please help me.
Это хороший вопрос?
Оценка 0
2 Комментариев:
Have you cleaned the inside of the console recently? Have you applied new thermal paste to the CPU recently?
из
@andrewsawesome yes, it appears to have no issues it has power running through the entire thing I have tested everything it seems to be fine
из
Добавить комментарий
1 ответ
Hello there,
Please refer to a YT channel like tronicsfix as he specializes in this console repair business.
I will try and solve it here.
Firstly, have you tried checking your connections?
Please let me know how this goes
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Yes, everything has a great connection I hear I sort of popping noise where the thermal paste is I replaced it recently.
из
Next, can you check voltages across the board?
из
Добавьте свой ответ
Trey Maines будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 72
