Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797вопросов Показать все
Dead battery needing manually charged
Does anyone know how to charge a dead lithium battery with another battery as I have a iPod that has a severely undervolting problem and I need to manually put charge into it
Any known methods
Any help will be greatly appreciated
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
The only method would be to wire positive to positive and negative to negative of both batteries. In theory 2 working batteries should balance their power until it gets even, but if you have one dead battery it may not work. However, unless you know for sure the dead battery is not internally shorted or deteriorated, I would avoid playing with lithium batteries, as they have the bad habit to catch fire when things go wrong.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for the advise
Il avoid doing it and buy a new one
Thanks! :D
из
Добавьте свой ответ
HelloMacOS будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 32
