Samsung Galaxy A02s, released in January of 2021
40вопросов Показать все
I dropped my phone and the screen is cracked.
I dropped my phone and the screen is cracked. The display is turning on for like 0.5 seconds at a time and then turning black. How can I fix this?
Это хороший вопрос?
Оценка 12
6 Комментариев
Haw i fixes my screen phone
из
Never drop my phone 📱
из
شرخ في الباغه
طريقه التصليح
из
Basically I dropped my phone by accident and the left button of my phone is cracked and the screen is not working
из
@emerickambella As far as the screen not working, it's almost certain that it broke when it was dropped and needs to be replaced. See my answer below for a guide showing you how to do that.
As far as the "left button is cracked" problem, you'll have to elaborate on that. According to Samsung your phone doesn't have any buttons on the left side of the phone; all three - power and volume up/down - are on the right side, so it's not clear what button you're talking about.
Your best bet for getting help is to start a new question and add pictures of the damage.
из
Показать 1 больше комментариев
Добавить комментарий
3 Ответов
Выбранное решение
You'll need to get the screen replaced. Check around local independent repair shops and get quotes. You can also fix it yourself if you're really comfortable with it
Был ли этот ответ полезен?
Оценка 5
2 Комментариев:
my phone is cracked and broken
из
I can not call or text anyone
из
Mezdari, assuming you're on topic here and you're referring to replacing the screen on a Samsung Galaxy A02s, then this guide should work to step you through the process of repairing your phone.
https://www.nadiemellamagallina.com/en/m...
Оценка 2
Je veux flaches mon téléphone
Оценка 0
1 Комментарий:
Je veux changé laficheur
из
Добавьте свой ответ
asdf будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 13
За последние 30 дней: 45
За всё время: 1,922
