Hi @jennypennysa ,
What is the model number of the dishwasher?
Can you hear if water is entering the dishwasher?
Can you hear if the dishwasher's circulation pump is operating?
Is there water standing in the dishwasher below the lower spray arms after it has started and filled but the spray arms haven't rotated? Start the dishwasher and allow it to fill, heat and wash for a few minutes then open the door and check.
With dishwashers it's not the water supply pressure that causes the spray arms to rotate, it is the circulation pump in the dishwasher.
Initially the control board opens the dishwasher's water inlet valve to let water into the dishwasher and it fills the sump in the dishwasher. This is the tray below the lower spray arms.
When the required water level is reached the water level pressure switch operates and the control board closes the water inlet valve to prevent more water from entering.
After that the water in the dishwasher is heated and when the required temperature is reached the heater is turned off and the circulation pump is started to pump the water from the sump through the spray arms under pressure, which causes them to rotate and wash the dishes. The wash water runs off the dishes and collects in the sump and is pumped through again in a cycle etc
If there is water in the dishwasher, as it is brand new contact the manufacturer's customer service section about a warranty repair
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
1 Комментарий
Hi there. Sooo yesterday was get the dishwasher going day. 1.was definitely pressure pump needed to be closer the to inlet of dishwasher and 2 we tried the old dishwashers pipe. Boom works a charm!!!! Thanks for your input. Much appreciated.
из Jenny Jordaan
