Sony CFS-204 — это аналоговый AM/FM-радиоприемник с кассетным проигрывателем в стиле 90-х годов. Устройство может работать от шести батареек типа C или от сети переменного тока через стандартную розетку.
Warning about opening plastic case
I have a similar Sony CFS-B11 with, I suspect, a broken belt in the tape player mechanism. The case carries dire warnings about electrocution upon opening the case. What do I need to do, beside unplugging the radio cassette corder from the electrical outlet, to open the case safely?
Это хороший вопрос?
Счет 0
1 Комментарий
Thanks! So helpful!
из
Добавить комментарий
1 ответ
Выбранное решение
Hi @sandhillgirl,
You may get a tingle from some capacitors discharging if you accidentally touch some sections of the power board with your fingers but that's about all. To prevent this from happening, after you've disconnected the power from the player, turn it on for a few minutes, to discharge any remaining charge in the capacitors. It won't turn on of course, but they will still discharge in trying to turn it on with no power connected ;-)
Here's a link to the service manual that will help. Be patient as it takes a little while to find the file after you have passed the security check.
It shows how to disassemble the player and the belt can be seen on p.6 in the tape adjustment section.
The belt part number is Sony 3-362-989-01. Search online using the part number only to find suppliers that suit you best.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Lisa буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 29
За все время: 658
